ComancheCrusher9800 Posted February 9, 2017 Share Posted February 9, 2017 Okay so when I try to pull the switch for the headlights the first click which I'm pretty sure is supposed to be low beams, only the dash lights come on along with the tail lights. And then the next click the high beams come on. And when I try to use the turn signals or flashers they stay lit. On the dash they stay solid and the rear lights stay solid. So my problem is the turn signals staying solid with the headlights on and my low beam isn't working. Any ideas? Link to comment Share on other sites More sharing options...
Hippie66 Posted February 9, 2017 Share Posted February 9, 2017 First click on the switch is parking lights. Headlights should not be on. Dimmer switch is on the left side of the column. Pull it towards the wheel to switch between high and low beam. Turn signals could be bad ground, bad flasher, or bad switch. My money is on the ground. Link to comment Share on other sites More sharing options...
mattbuch96 Posted February 9, 2017 Share Posted February 9, 2017 I had to replace turn signal light socket on mine Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Gene Posted February 9, 2017 Share Posted February 9, 2017 Hi crusher, So when you pull the headlight switch all the way out, the headlights will come on. What happens when you pull the turn signal switch lever toward you? Do the low beams come on? Do the high beams stay on? Or do the headlights go out? Gene Link to comment Share on other sites More sharing options...
ComancheCrusher9800 Posted February 10, 2017 Author Share Posted February 10, 2017 Okay so the headlights dim with that. I had completely forgot that that's how you dim them. But my problem now is with the blinkers staying solid Link to comment Share on other sites More sharing options...
ComancheCrusher9800 Posted February 10, 2017 Author Share Posted February 10, 2017 And the turn signals blink when the headlight or parking lights are off. But when they are on they stay solid Link to comment Share on other sites More sharing options...
RustyRodder Posted February 10, 2017 Share Posted February 10, 2017 on mine it did that on the right signal- had an incorrect bulb screwing up the system. Link to comment Share on other sites More sharing options...
Hippie66 Posted February 10, 2017 Share Posted February 10, 2017 Check bulbs and grounds. Link to comment Share on other sites More sharing options...
