Newton Posted January 31, 2017 Share Posted January 31, 2017 My turn signals do not work however the hazards do work all fuses checked also swapped the hazard flasher relay for the turn signal in fuse box but still no luck also my wiper wouldnt park and would only work on max speed checked out the intermittent delay module and the thing was completely toast broken parts and heavy rust inside do you think that might have something to do with the turn signals not working? nd if not is there a way to test the turn signal switch on the column to know if its bad..like what color wires for left and right signals coming from the steering column Link to comment Share on other sites More sharing options...
Kalal92 Posted January 31, 2017 Share Posted January 31, 2017 There's a in and out switch on the steering column on the right side pull it out or in in the turn signal should work. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Newton Posted January 31, 2017 Author Share Posted January 31, 2017 There's a in and out switch on the steering column on the right side pull it out or in in the turn signal should work. Sent from my iPhone using Tapatalk Any pictures of what it look like? Link to comment Share on other sites More sharing options...
cruiser54 Posted January 31, 2017 Share Posted January 31, 2017 There's a in and out switch on the steering column on the right side pull it out or in in the turn signal should work. Sent from my iPhone using Tapatalk Any pictures of what it look like? I think he means the Hazard switch maybe? But, you already said the Hazards work. That said, are you saying all the flashers work outside the vehicle just fine, with or without headlights on? Link to comment Share on other sites More sharing options...
Newton Posted January 31, 2017 Author Share Posted January 31, 2017 There's a in and out switch on the steering column on the right side pull it out or in in the turn signal should work. Sent from my iPhone using Tapatalk Any pictures of what it look like? I think he means the Hazard switch maybe?But, you already said the Hazards work. That said, are you saying all the flashers work outside the vehicle just fine, with or without headlights on? Yess all hazard lights work outside with and without the headlights on Link to comment Share on other sites More sharing options...
87MJTIM Posted January 31, 2017 Share Posted January 31, 2017 I had a similar issue several years ago. Flashers worked. No turn signal or brake lights. I first replaced brake light switch. Did not fix it. I studied the wiring diagram and found the common connection for the two was the turn signal directional switch. Replaced it and the problem was fixed. I have not had the problem since. http://www.morris4x4center.com/turn-signal-switch-directional-56002011.html Link to comment Share on other sites More sharing options...
Newton Posted January 31, 2017 Author Share Posted January 31, 2017 I had a similar issue several years ago. Flashers worked. No turn signal or brake lights. I first replaced brake light switch. Did not fix it. I studied the wiring diagram and found the common connection for the two was the turn signal directional switch. Replaced it and the problem was fixed. I have not had the problem since. http://www.morris4x4center.com/turn-signal-switch-directional-56002011.html I was hoping that switch wouldnt have been the issue as i don't have the tools required to remove the steering but the more research i do is the more i realize I'm gonna have to bite the bullet and get the tools and that switch and a couple 6packs Link to comment Share on other sites More sharing options...
87MJTIM Posted January 31, 2017 Share Posted January 31, 2017 Most auto parts stores let you rent tools. The steering wheel puller is usually one of them. Link to comment Share on other sites More sharing options...
Newton Posted January 31, 2017 Author Share Posted January 31, 2017 Is there any way to test that switch before i attempt to replace it? Link to comment Share on other sites More sharing options...
87MJTIM Posted January 31, 2017 Share Posted January 31, 2017 Get a wiring diagram and a multi-meter. Link to comment Share on other sites More sharing options...
cruiser54 Posted February 1, 2017 Share Posted February 1, 2017 Hazard and turn signals are on different fuses........... Link to comment Share on other sites More sharing options...
87MJTIM Posted February 1, 2017 Share Posted February 1, 2017 Hazard and turn signals are on different fuses........... He said is hazards work, but turn does not. I found that when I had similar issues. The signal switch was the common unit for both the TURN and BRAKE. Link to comment Share on other sites More sharing options...
cruiser54 Posted February 1, 2017 Share Posted February 1, 2017 Hazard and turn signals are on different fuses........... He said is hazards work, but turn does not. I found that when I had similar issues. The signal switch was the common unit for both the TURN and BRAKE. Yet they're on different fuses........ Don't think he should check that? One fuse is Turn B/U and the other is Haz/Stop. Link to comment Share on other sites More sharing options...
87MJTIM Posted February 1, 2017 Share Posted February 1, 2017 True. Start with the easy stuff first. Link to comment Share on other sites More sharing options...
cruiser54 Posted February 1, 2017 Share Posted February 1, 2017 True. Start with the easy stuff first. I just went out to the garage and pulled the Turn/BU fuse on my 87 MJ. Hazards worked with or without key On and turn signals didn't work at all...... Link to comment Share on other sites More sharing options...
Racko Posted May 1, 2017 Share Posted May 1, 2017 Did you end up getting this fixed? I believe I have the same exact problem Link to comment Share on other sites More sharing options...
