FLETCH14519 Posted January 24, 2017 Share Posted January 24, 2017 I was searching around to find a good part number for the front and rear vacuum line harness for my 87 4.0 Comanche. From what I found, the 715-1366 and 715-1367 (NAPA NUMBERS) will not work with the 87's due to certain hoses not reaching or lining up? Does anyone know a good part number for the 87's Vacuum line assembly (front and rear)? I did find a good CROWN P#: 53004375 , but looking for the other half for the full assembly. Link to comment Share on other sites More sharing options...
Crash Posted January 25, 2017 Share Posted January 25, 2017 I'll see if I can find it. But I know there's at least one thread on naxja. Probably here too. Link to comment Share on other sites More sharing options...
jerpderp Posted January 25, 2017 Share Posted January 25, 2017 I used NAPA harnesses on my 87. Worked fine. Not a perfect fit but pretty close. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
FLETCH14519 Posted January 25, 2017 Author Share Posted January 25, 2017 I'll see if I can find it. But I know there's at least one thread on naxja. Probably here too. Okay sounds good. Thank you Link to comment Share on other sites More sharing options...
FLETCH14519 Posted January 25, 2017 Author Share Posted January 25, 2017 I used NAPA harnesses on my 87. Worked fine. Not a perfect fit but pretty close. Sent from my iPhone using Tapatalk is everything still hook up like it should? Was there any modifications? Link to comment Share on other sites More sharing options...
jerpderp Posted January 26, 2017 Share Posted January 26, 2017 The two main vac harnesses Hooked up as they should. The routing wasn't as perfect as the factory, but they work with no leaks. The line from the rear of the valve cover to the intake manifold wasn't close, so I reused the stocker. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
jerpderp Posted January 26, 2017 Share Posted January 26, 2017 I have an engine photo in my build thread Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
cruiser54 Posted January 26, 2017 Share Posted January 26, 2017 It's all right in the link below. http://cruiser54.com/?p=121 Link to comment Share on other sites More sharing options...
Whiz Posted January 27, 2017 Share Posted January 27, 2017 I got mine on Amazon https://www.amazon.com/gp/product/B000630DJ4/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B000630DJO/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1 Link to comment Share on other sites More sharing options...
