Tex06 Posted January 15, 2017 Share Posted January 15, 2017 Welp, I broke my T for the radiator hoses. Does anyone have a list of parts for the conversion to 96+ and maybe a good pic? Hornbrod, I know you did a great job with yours. I'm looking to buy everything off rockauto if possible. Sent from my SM-G930T using Tapatalk Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted January 15, 2017 Share Posted January 15, 2017 Upper and lower heater hoses for 97+ cherokee , some hose clamps ( unless you like the spring clamps ) and something to plug the vacuum hose that goes to the heater valve . Link to comment Share on other sites More sharing options...
Tex06 Posted January 15, 2017 Author Share Posted January 15, 2017 Upper and lower heater hoses for 97+ cherokee , some hose clamps ( unless you like the spring clamps ) and something to plug the vacuum hose that goes to the heater valve .Does that replace all 4 hoses? I noticed that the water pump has 2 hoses coming off it going to that Tee. Sent from my SM-G930T using Tapatalk Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted January 15, 2017 Share Posted January 15, 2017 Yep , the 2 hoses replace all 4 . Link to comment Share on other sites More sharing options...
Tex06 Posted January 15, 2017 Author Share Posted January 15, 2017 For the '98 Cherokee, I'm about to order the inlet and outlet hoses. They also list: Valve to pipe Valve to heater Valve to thermostat. Don't need these, correct? Sent from my SM-G930T using Tapatalk Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted January 15, 2017 Share Posted January 15, 2017 The 19039/19038 is all you need Link to comment Share on other sites More sharing options...
1987Comanche Posted January 15, 2017 Share Posted January 15, 2017 I cheated and used 5/8" and 3/4" heater hose. To fit the 5/8" hose on the 3/4" fitting I stuck the end of the hose in boiling water to soften it up. Not as pretty as the molded hoses but it was dirt cheap. Link to comment Share on other sites More sharing options...
HOrnbrod Posted January 15, 2017 Share Posted January 15, 2017 Just use the Mopar molded hoses, much neater. You'll also need the hose bracket if you don't have one already. It's press fit on one of the valve cover studs and holds the hoses off the block. P/n 55035933AB, about $8 from the dealer. Link to comment Share on other sites More sharing options...
Tex06 Posted January 15, 2017 Author Share Posted January 15, 2017 Thanks guys. I have the bracket already. Ordered the two gates pre-formed hoses. Sent from my SM-G930T using Tapatalk Link to comment Share on other sites More sharing options...
schardein Posted January 15, 2017 Share Posted January 15, 2017 I recently changed over both my MJ and XJ. I used Dayco 87792 and Dayco 88249 (from Rockauto). These are molded hoses that fit perfectly and look great. Link to comment Share on other sites More sharing options...
