tjbuggie Posted January 9, 2017 Share Posted January 9, 2017 So, I am finally getting to do some work on my new to me 1988 base comanche. It sat for about a year before I picked it up, and now that I have got it running, I have a bad stumble right off of idle, once I get passed this it runs good. It also seems to have to crank a few times before it starts. Anyone got ant ideas of where I should start to look to get this solved?? Link to comment Share on other sites More sharing options...
cruiser54 Posted January 9, 2017 Share Posted January 9, 2017 Go to www.cruiser54 and complete Tips 1 through 5. How do the plugs, wires, cap and rotor look? Link to comment Share on other sites More sharing options...
tjbuggie Posted April 21, 2017 Author Share Posted April 21, 2017 Ok, bringing this back up, I have replaced the battery cables with new ones from mean lemons, cleaned the c101 and looked over the wiring, still have the problem. I did notice if you unplug the vacuum line to the MAP sensor it does not have the stumble, but runs very rich.....tried a new MAP sensor but got no change. It does seem to be less of a problem once the jeep warms up......any ideas on where to look now?? Link to comment Share on other sites More sharing options...
big66440 Posted April 21, 2017 Share Posted April 21, 2017 I'd do all of cruisers tips to have a foundation for a better diagnosis down the line and everyone here will point you in that direction anyway. I did them and they fixed issues I didn't even know I had. Link to comment Share on other sites More sharing options...
cruiser54 Posted April 22, 2017 Share Posted April 22, 2017 I'd do all of cruisers tips to have a foundation for a better diagnosis down the line and everyone here will point you in that direction anyway. I did them and they fixed issues I didn't even know I had. Well stated, and very true. fix known issues first for nearly free and then carry on if needed. Link to comment Share on other sites More sharing options...
tjbuggie Posted April 24, 2017 Author Share Posted April 24, 2017 Did tips 1-5 still having trouble. Also when I adjust the TPS I can reduce the stumble but then I get a high idle and poping at higher RPM. I did notice that I have a TPS for an auto tranny and I have a 5 speed, could this be causing problems?? Link to comment Share on other sites More sharing options...
omega_rugal Posted April 24, 2017 Share Posted April 24, 2017 is the EGR working? O2 sensor ok? i would look there... Link to comment Share on other sites More sharing options...
cruiser54 Posted April 24, 2017 Share Posted April 24, 2017 Did tips 1-5 still having trouble. Also when I adjust the TPS I can reduce the stumble but then I get a high idle and poping at higher RPM. I did notice that I have a TPS for an auto tranny and I have a 5 speed, could this be causing problems?? Having a TPS for an auto is no problem. Did tips 1-5 still having trouble. Also when I adjust the TPS I can reduce the stumble but then I get a high idle and poping at higher RPM. I did notice that I have a TPS for an auto tranny and I have a 5 speed, could this be causing problems?? What were the results of tip 5? Ohms.... Link to comment Share on other sites More sharing options...
tjbuggie Posted April 25, 2017 Author Share Posted April 25, 2017 Less than 1 Ohm at tip 5 all ground connections were good and tight as well as clean to the point of still looking new.... Link to comment Share on other sites More sharing options...
cruiser54 Posted April 26, 2017 Share Posted April 26, 2017 Good deal. c101. How dirty? Link to comment Share on other sites More sharing options...
tjbuggie Posted April 26, 2017 Author Share Posted April 26, 2017 Sent about 45 minutes cleaning it a few weeks back......so it is good and clean Link to comment Share on other sites More sharing options...
tjbuggie Posted May 3, 2017 Author Share Posted May 3, 2017 replaced TPS and IAC last night and the truck runs great now..... Link to comment Share on other sites More sharing options...
cruiser54 Posted May 4, 2017 Share Posted May 4, 2017 Thanks for posting back. Link to comment Share on other sites More sharing options...
