DirtyComanche Posted December 13, 2016 Share Posted December 13, 2016 This is a pretty common swap in 'the rest of the world.' Curious if anyone has done so on the MJ/XJ platform and what problems they ran into? I seriously need to upgrade my brake booster, but just going out and doing something that's proven and easy would be boring... Plus I can probably snag a hydroboost and master for very little money from the 'yard. Nope, I haven't done even the most basic of research such as to check the MC bore size or what other MCs bolt to it, but I will later tonight. Link to comment Share on other sites More sharing options...
Mattman6 Posted December 13, 2016 Share Posted December 13, 2016 Why not just get the 95-96 XJ brake booster/master and call it a day? Link to comment Share on other sites More sharing options...
Hippie66 Posted December 13, 2016 Share Posted December 13, 2016 Just curious what's wrong with the stock booster and master cylinder? I have no issues with my '89. Link to comment Share on other sites More sharing options...
Marine1Texas Posted December 13, 2016 Share Posted December 13, 2016 with over size tires you will come in to braking issues is one reason people do the brake upgrade. anything 31 and bigger! Link to comment Share on other sites More sharing options...
big66440 Posted December 13, 2016 Share Posted December 13, 2016 I'm not trying to sound like an @$$ but I don't think you guys got the point of the OP's post, he wants to do something different and was asking if anyone had experience with his idea to run a GM hydro boost setup. Link to comment Share on other sites More sharing options...
bcbill Posted February 24, 2017 Share Posted February 24, 2017 Any luck with the research on this Dirty C..... with my limited experience with square body GMs my thinking is it will fit on firewall, the exciting part might be in fitting in the power steering pump, Link to comment Share on other sites More sharing options...
DirtyComanche Posted February 24, 2017 Author Share Posted February 24, 2017 Any luck with the research on this Dirty C..... with my limited experience with square body GMs my thinking is it will fit on firewall, the exciting part might be in fitting in the power steering pump, I kinda shelved it for the time being, and haven't done anything about it. I was trying to snag a Ford unit and an Astro unit to try fitting up, but both of the ones I was going for slipped away on me. I also want to get my other chassis over to try fitting it on, since I am daily driving my MJ right now. As for the pump I was probably just going to get the 01-04 V8 WJ pump, it fits nicely onto the Renix or early HO brackets (you need to either swap the pulley or mill about .300" off the bracket, I milled the one in my XJ when I did it). This pump is factory ported and has the best flow characteristics of any TC pump, plus the reservoir has dual return ports. I believe at least the GM hydroboosts use the same fittings as an XJ/MJ, so the XJ/MJ pump outlet fitting in the WJ pump should allow you to run GM pressure hoses. There may be some messing around to get ones that fit well, I was going to look at my plowtruck at some point since it runs a GM hydroboost although it is the more typical P pump setup. If all else fails Vanco sells fittings and hoses for generic installations. I would do some costing prior to actually purchasing anything other than mockup parts. Getting a WJ booster and master is probably a more economical swap. It is only $125 for a reman booster, or $150 for a new one off Rockauto (Canadian pricing), and $85 for a new master cylinder with reservoir. Junkyard parts should be cheaper. Link to comment Share on other sites More sharing options...
bcbill Posted February 24, 2017 Share Posted February 24, 2017 Just picked up a 97 xj booster and master from Gary's Maple Ridge $40. Sent from my iPad using Tapatalk Link to comment Share on other sites More sharing options...
SBpunk Posted February 24, 2017 Share Posted February 24, 2017 Head over to FSJnetwork and check out their stuff on it over there. Little different but not much. Front disc rear drum just like us and they're heavier. The boosters aren't much different from ours either. Link to comment Share on other sites More sharing options...
