Brake Master Cylinder ?
ok so i put on the new brake parts and i happy that i go the stupid leak to stop
but now when i drive the truck up and down the road
it won't stop the vehicle i have to pull the parking break to get the vehicle to stop
can anyone tell me what i did wrong ?
is it soft? is it hard? you have to give us more info. did you bleed the lines?
He means the brake pedal. Does it go to the floor (or almost) really easy? Or does it feel stiff when you step on it?
Brakes have to be bled of air when you work on them because air is compressible. YouTube "How to bleed brakes". It's pretty much the same on any common car, truck, or suv.
Sent from my SM-G930T using Tapatalk
ok so here's what i did
i had no clamp to bench bleed the MC
so i just bolted the MC to the booster and connected rubber tubes to back feed the fluid back into the mc
i did that until the air bubbles stopped took about 30 minutes
then i removed the rubber tubes and reconnected the metal brake fluid lines with a flare wrench and reconnect the vacuum tube hose to the booster
then i pumped the brakes like 20 times fully started the vehicle and tested them out
when i press them i get a medium amount of resistance but i can push it all the way down to the floor board
it seems like there is not enough hydraulic pressure to move the brake pads
ok thats what i figured
so i took the driver wheel off and tried un bolting the bleeder screw
and it didn't budge at all i cleaned if off with a wire brush then sprayed it with WD40
and all i managed doing was stripping it :(
so tomorrow i will try to weld a flat piece of metal to it and see if i can hammer it off
You didn't bleed the lines to the wheels. Just pumping the peddle doesn't do anything for you.
and all i managed doing was sripping it :(
Careful welding to brakes. Welding fluid is pretty flammable stuff. I've had success in the past removing the wheel and carefully heating the bleeder screw (just the screw, not the caliper in disc or brake cylinder on drum) then removing it very slowly with vise grips. After it breaks free let it cool. You'll need new bleed screws if you do this though.
Don't weld. Use vise-grips. And go easy -- if you break off the outer part, then you'll have to buy a new caliper (or wheel cylinder, depending on which end you're working on).
In fact, wheel cylinders aren't expensive. Considering the age of your truck, it might not be a bad idea to just buy new wheel cylinders and start fresh.
And don't use WD-40 for penetrating oil. That's not what it's for, and it doesn't work. Use PB Blaster, or (even better) Kroil -- if you can find it.
I have had good luck using a 50/50 mix of transmission fluid and paint thinners in a spray bottle to loosen seized bolts.
Sent from my SM-N900W8 using Tapatalk
i have been trying to use vise grips and i can't get it to budge at all
i think I'm going to just heat up the bolt and that should pry it free
Are you working on a caliper or a wheel cylinder? Keep in mind that the bleeder screws are brass, so they are easier to mess up. At least for the wheel cylinders, I think you shouldn't waste any time trying to free up stuck bleeders. Just buy new wheel cylinders and install them. Your master cylinder was so bad it was leaking, so I would expect the wheel cylinders to be in equally bad condition. Rear wheel cylinders are $10 from Autozone -- new.
Their remanufactured front calipers are $21.99, and they have a lifetime warranty. You decide how much effort you want to put into something that probably needs to be replaced anyway.
i may have to buy new calipers hopefully i don't because the original ones work and they say AMC on them so i want to keep then because they are original
You can buy rebuild kits or new ones and transfer the seals. If you're careful :D
Rebuild kits won't help much if he snaps off a bleeder screw in the caliper.
Good News guys i got the bleeder screw out
i found out that if you allow plenty of heat and give it hard hits with a hammer the vibrations will break it free and allow you to turn it
now i just got to go buy new bleeder screws
Excellent. Thanks for the update.
That's what an easy-out is for.  Or weld a nut onto the broken bleeder...  I've broken more than a few off and never trashed a caliper because of it.
