Torq's 1990 Eliminator
Being that I have actually started working on my project Comanche I needed to start documenting it. This is my 4th Jeep and 2nd Comanche. I expect this build to be somewhat slow but extremely extensive. This will not be an offroad build per-se but I am planning some interesting stuff.
Specs:
1990 Comanche Eliminator
All factory skids
AX-15
4x4
3.07s and open D35 rear
235/75/15s on TJ wheels
In progress projects:
WJ Brake booster
WJ Knuckles and Front Brakes
WJ Steering (UTK shortened factory tie rods)
Minor Plans:
Rust repair (floorboards and windshield frame)
Vinyl flooring in cab
Paint Job
New window seals
Fix rear bumper and tailgate (minor fender bender)
Major Plans:
97+ Front clip
Ford 8.8 LSD with discs out back (Gearing TBD)
GM 2.0L Turbo LHU engine swap (This WILL happen, hopefully in 2017)
First day home, Tires were super dry-rotted. Last registered 2013
New tires/rims. Probably temporary but they were cheap and allowed me to actually drive it. THRJYz3.jpg
Seafoam treatment... Motor was missing. Seafoam treatment fixed that. nhMU4cP.jpg
And my old truck just for good measure. I really miss that thing. College tuition stole it from me. ldJw755.jpg
Do you have any more info on the WJ booster swap.  I just put an 8.8 in my Eliminator and would like something more compatible with the rear disc setup.  Thanks.
Changed the master cylinder/brake booster to a WJ one. Somehow I messed up the distance for the brake light switch so I bought one for a 1980 C10 and built a bracket that bolted to the brake booster bolts on the firewall.
http://comancheclub.com/topic/24430-wj-booster-and-master-cylinder-upgrade/
  • 4 weeks later...
I like the outside the box engine swap idea. I've been working on a Honda engine swap into my wrangler. Hoping to start pulling my motor next month.
someone here started an sr20 swap but it's been a while since they posted,
