madog7200 Posted November 4, 2016 Share Posted November 4, 2016 Does the comanche clutch pedal cross over with any other vehicle? And is does anyone have the part number for the original? Sent from my SM-G930P using Tapatalk Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted November 4, 2016 Share Posted November 4, 2016 It does with Cherokees. When I did my ax15 swap I used a 95 pedal and assembly in my 87 comanche Link to comment Share on other sites More sharing options...
madog7200 Posted November 4, 2016 Author Share Posted November 4, 2016 It does with Cherokees. When I did my ax15 swap I used a 95 pedal and assembly in my 87 comancheAre there any writeups on how to remove the assembly and replace it? I have to replace mine since it broke at the weld Sent from my SM-G930P using Tapatalk Link to comment Share on other sites More sharing options...
Marine1Texas Posted November 4, 2016 Share Posted November 4, 2016 Mine broke too, I just re-welded it Link to comment Share on other sites More sharing options...
madog7200 Posted November 4, 2016 Author Share Posted November 4, 2016 How hard Was it to remove? Sent from my SM-G930P using Tapatalk Link to comment Share on other sites More sharing options...
Marine1Texas Posted November 4, 2016 Share Posted November 4, 2016 a tight area to work in, however removal was not hard at all. just getting in the area without being a pretzel ! it is pretty straight forwars. just make sure to disconnect the rods from break and clutch, no need to do a extra repair. Link to comment Share on other sites More sharing options...
jeepsouth Posted November 4, 2016 Share Posted November 4, 2016 Rewelded mine too. Link to comment Share on other sites More sharing options...
madog7200 Posted November 5, 2016 Author Share Posted November 5, 2016 I've decided to just go the reward route as well... i work at a 18 wheeler shop so I can have a guy at work weld it in there spare time thanks for the help guys! Sent from my SM-G930P using Tapatalk Link to comment Share on other sites More sharing options...
SVPete Posted November 5, 2016 Share Posted November 5, 2016 a tight area to work in, however removal was not hard at all. just getting in the area without being a pretzel ! it is pretty straight forwars. just make sure to disconnect the rods from break and clutch, no need to do a extra repair. I pulled mine on the side of the road about 25 years ago and had it re-welded for a buck. Don't remember it being too difficult. Link to comment Share on other sites More sharing options...
Marine1Texas Posted November 5, 2016 Share Posted November 5, 2016 The first time for me I pulled it. The 2nd mj I welded it in place Link to comment Share on other sites More sharing options...
