That_Creepy_Guy_In_The_MJ Posted November 3, 2016 Share Posted November 3, 2016 Alrighty, so basically I have plans to convert my 1988 mj to 4wd and I just wanted to know like a small grocery list of items I'd need to get the job done. Only reason I'm going 4wd is for the capabilities, and I'd like to put on a 4.5" lift kit. Link to comment Share on other sites More sharing options...
Francesco Posted November 3, 2016 Share Posted November 3, 2016 Okay, So I did this one myself. This is a COMPLETE(if i remember correctly) list of what I needed:4wd Transmission 4wd pilot bearing 4wd shift linkage front driveshaft and rear (different size) 4wd engine harness (if you want the 4wd light, etc) front axle front brakes (they weren't the same for me, i think it was the knuckles that were different which made the calipers different too) i replaced my unit bearings too, AFAIK the 2wd ones have a plug you can remove, but IDK. I highly recommend finding an external slave transmission (assuming youre a 5 speed) while everything is apart. Will save you lots of time if your slave goes out (and mine already has) Link to comment Share on other sites More sharing options...
That_Creepy_Guy_In_The_MJ Posted November 3, 2016 Author Share Posted November 3, 2016 Thank you! Link to comment Share on other sites More sharing options...
Pete M Posted November 3, 2016 Share Posted November 3, 2016 manual or auto? the pilot bearing isn't 4wd specific, that will change (or not) depending on what trans you put in. :thumbsup: not sure what you mean by the "4wd engine harness" but I'm pretty sure you're referring to the vacuum harness that runs off the t-case. and as he said, the brakes must match the new axle. 2wds are different and there have been changes on the 4wd ones over the years. now is the time for gearing upgrades. better gears were available in 2.5L rigs and (unless you have the dana 44 rear) you'll want to upgrade your dana 35 too. now is also the time to consider the front U-joints too, as the later years of XJ (also the early 90s with ABS) has bigger ones. these axle shafts are swappable into early axles if you find an early one with better gears. a donor rig can help with a straight swap, but no XJ came with all the goodies. for example, even later 4.0 XJs had 3.55 gears at best. Link to comment Share on other sites More sharing options...
That_Creepy_Guy_In_The_MJ Posted November 3, 2016 Author Share Posted November 3, 2016 Yea I have a manual 4 speed. Link to comment Share on other sites More sharing options...
That_Creepy_Guy_In_The_MJ Posted November 3, 2016 Author Share Posted November 3, 2016 And reason for the 4wd as mentioned is so I can lift it higher, and the capabilities Link to comment Share on other sites More sharing options...
davidh190 Posted November 4, 2016 Share Posted November 4, 2016 manual or auto? the pilot bearing isn't 4wd specific, that will change (or not) depending on what trans you put in. :thumbsup: not sure what you mean by the "4wd engine harness" but I'm pretty sure you're referring to the vacuum harness that runs off the t-case. and as he said, the brakes must match the new axle. 2wds are different and there have been changes on the 4wd ones over the years. now is the time for gearing upgrades. better gears were available in 2.5L rigs and (unless you have the dana 44 rear) you'll want to upgrade your dana 35 too. now is also the time to consider the front U-joints too, as the later years of XJ (also the early 90s with ABS) has bigger ones. these axle shafts are swappable into early axles if you find an early one with better gears. a donor rig can help with a straight swap, but no XJ came with all the goodies. for example, even later 4.0 XJs had 3.55 gears at best. Pete, my MJ is auto. How would I approach the 4wd conversion? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Pete M Posted November 4, 2016 Share Posted November 4, 2016 same principles. just skip the parts related to the manual trans. I believe there is a writeup in the DIY forum that cover using later model transmissions (the electronics changed over the years). http://comancheclub.com/topic/48710-diy-projects-writeups-master-search-index/ Link to comment Share on other sites More sharing options...
mikekaz1 Posted November 4, 2016 Share Posted November 4, 2016 Do yourself a favor and skip the factory linkage and get a bostwerks or similar stand alone linkage. Link to comment Share on other sites More sharing options...
That_Creepy_Guy_In_The_MJ Posted November 5, 2016 Author Share Posted November 5, 2016 Alrighty I'll do that Link to comment Share on other sites More sharing options...
