davidh190 Posted September 14, 2016 Share Posted September 14, 2016 Hi guys, So I replaced the drums, rotors, brake shoes and pads, and the wheel cylinders. The brake pedal was sinking in so I replaced the master cylinder. It kept doing that so I replaced that cylinder along with the power brake booster. Although the brake pedal feels much better, when I've been driving around for a while, I feel the brake pedal goes down a little too much. Am I going crazy or is there something else I should check? Here's a pic of my truck. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 14, 2016 Share Posted September 14, 2016 Couple of things to check: Did you re-adjust your rear brake shoes with the star wheel so they just barely drag when rotating the wheel? Did you check the booster vacuum check valve? Link to comment Share on other sites More sharing options...
cruiser54 Posted September 14, 2016 Share Posted September 14, 2016 Excellent points^^. Link to comment Share on other sites More sharing options...
mikekaz1 Posted September 15, 2016 Share Posted September 15, 2016 If its a booster issue, wouldnt it get harder rather then softer? Soft/sinking is normally a fluid loss or air bubble. How much did you bleed when replacing everything? Link to comment Share on other sites More sharing options...
davidh190 Posted September 15, 2016 Author Share Posted September 15, 2016 Couple of things to check: Did you re-adjust your rear brake shoes with the star wheel so they just barely drag when rotating the wheel? Did you check the booster vacuum check valve? No sir, but I will check that out tomorrow. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
FrankTheDog Posted September 15, 2016 Share Posted September 15, 2016 Did you follow the proper procedure to bleed the rear brakes with the proportioning valve? It is outlined somewhere on this site. Link to comment Share on other sites More sharing options...
big66440 Posted September 16, 2016 Share Posted September 16, 2016 If you have the original single diaphragm booster the pedal is naturally a bit "mushy" and does seem to go lower than the average vehicle from what I can remember, that was part of the reason I went with the 95-96 XJ dual diaphragm set up. Link to comment Share on other sites More sharing options...
