ejndssn Posted July 6, 2007 Share Posted July 6, 2007 All right have any of you folks split the clutch pedal at the pivot point. What was correction taken to prevent future occurrences? :dunno: quick fix is to get another one and mig weld the crack/split :brows: any thoughts would be appreciated. 89MJ with 94 AX-15 setup Link to comment Share on other sites More sharing options...
Pete M Posted July 6, 2007 Share Posted July 6, 2007 It's rare, but not unheard of. If I remember right, the solution is simply to replace the broken part. Unless something else is wrong, it shouldn't happen again. :D Link to comment Share on other sites More sharing options...
KYMJ Posted July 6, 2007 Share Posted July 6, 2007 Had one break on my 4x4. Went to the pull a part and got one off a junk XJ. The old one had been welded once. Link to comment Share on other sites More sharing options...
Rokhound Posted July 6, 2007 Share Posted July 6, 2007 weld it that is what i did and it is still together. If you price a new one hold on to you seat it is like 150 if I recall :nuts: or junk yard a new to you one. Link to comment Share on other sites More sharing options...
ejndssn Posted July 6, 2007 Author Share Posted July 6, 2007 thanks for the update i got lucky :cheers: and found one in the JY for ten bucks and i'm going to try to weld it for practice and see what i can do since this is new for me :jump: Link to comment Share on other sites More sharing options...
