How far does the pulley need to be engaged onto the power steering pump?
Just like the title says, how far?
I installed a new pump and have it fairly lined up but I figured there was a specific measurement to ensure it's properly placed onto the pump relative to something.
I should have checked it before pulling but overlooked it. The snout of the pump is recessed into the pulled probably 3/8". Just wasn't sure if it was supposed to be flush or not.
A few years ago I replaced the pumps on my MJ and my XJ, same day, same pump.  The 90 XJ pulley shaft was slightly recessed, The 88 MJ shaft was flush.  Both metal pulleys, one was solid, the other had spokes of a sort. As fiatslug says, as long as it's lined up with two other pulleys, you should be OK.
