Jackrabbit41 Posted June 10, 2016 Share Posted June 10, 2016 Damn it rough country! The wrong end came disconnected!!! Lol. Today when I was driving I heard a pop and then when I was at the local hardware store a guy asked "what's that thing hanging down by the diff?" It was the RC away bar disconnect. The bolt came out of the top. Weird because it had a lock but on it. Yes it was probably my fault but everything I've ever had that was rough country has just been $#!& Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
88whitemanche Posted June 10, 2016 Share Posted June 10, 2016 That's happened me to me a couple of times with my set... I ended up using a 3/8"-1" with a lock washer... Link to comment Share on other sites More sharing options...
gogmorgo Posted June 10, 2016 Share Posted June 10, 2016 Nylocks suck. They're only good for a couple uses and even the first one doesn't always go great. If you can find distorted thread nuts, they clamp down good for things you don't plan on pulling apart very often, although they usually end up screwing up the bolt so they're pretty well single-use only, although I have reused them successfully, just not many times. You can also use the good old double-nut, smash the nuts against each other and they should hold themselves in place. Link to comment Share on other sites More sharing options...
Dom U Posted June 11, 2016 Share Posted June 11, 2016 Love my RE discos. So far the ONLY RC item on my truck Is the track bar Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted June 11, 2016 Author Share Posted June 11, 2016 Love my RE discos. So far the ONLY RC item on my truck Is the track bar Get rid of it before it comes off and you die lol. Link to comment Share on other sites More sharing options...
