the uphill battle -
Hi Gang, I've got a slight problem and I wonder if there is any suggestions to perhaps help or if its just the way it is and that's it. First I've got a 87 4.0 2WD pretty much stock with autotrans -  runs great, engine is rebuilt with maybe 15K on it, mostly new everything radiator, electrical stuff, exhaust etc. one of the main reasons I got my  was to have a cooler older truck to haul my vintage bikes (not huge things usually 400 lbs tops) to meets and the likes. I've noticed on flat ground the temperature is fine ( <205) but if I hit a grade the temps slowly rise to about 210-215'+ish, thing is these are somewhat long'ish grades, but not like a real mountain run, just the typical SoCal Grapevine deal (4000') - I do have the auxiliary fan on a switch and turn it on when hitting the grades to help - not sure how much it does. Anyway there is a meet in a few months in the sierra's that I'd like to hit up and it will be a real uphill tote -  is there anything I can add to help the truck remain cool (the radiator is a new one but is stock size, new thermostat, hoses etc)  without doing major modifications? any help appreciated
thanks as always Mike
yeah hadn't thought about the coolant mixture Junkie - but bet your right on the 50/50 mix (I just kinda eyeballed it when I drained it and refreshed when I installed new water pump!)
yeah -  like I said it seems fine just worried about the potential Sierra's  hill climb for next event and watching the thing boil over - I probably shouldn't of put the temp gauge in and just used the idiot lights - ignorance is bliss sort of deal hahaha
