dcramer67 Posted May 20, 2016 Share Posted May 20, 2016 My sway bar is rubbing the coil on the passenger side. Do my coils need to be more narrow, or is something bent or off? Sent from my SAMSUNG-SM-N910A using Tapatalk Link to comment Share on other sites More sharing options...
Megadan Posted May 20, 2016 Share Posted May 20, 2016 These might be of interest.http://comancheclub.com/topic/49830-did-my-lift-swaybar-clearance/ http://comancheclub.com/topic/50203-whats-wrong-with-my-sway-bar/The sway bar relocation brackets/mounts in the second link might be of the most interest to you if you already have longer links. Link to comment Share on other sites More sharing options...
dcramer67 Posted May 21, 2016 Author Share Posted May 21, 2016 These might be of interest. http://comancheclub.com/topic/49830-did-my-lift-swaybar-clearance/ http://comancheclub.com/topic/50203-whats-wrong-with-my-sway-bar/ The sway bar relocation brackets/mounts in the second link might be of the most interest to you if you already have longer links. I think those relocation brackets should work. Thanks! Sent from my SAMSUNG-SM-N910A using Tapatalk Link to comment Share on other sites More sharing options...
Megadan Posted May 21, 2016 Share Posted May 21, 2016 These might be of interest. http://comancheclub.com/topic/49830-did-my-lift-swaybar-clearance/ http://comancheclub.com/topic/50203-whats-wrong-with-my-sway-bar/ The sway bar relocation brackets/mounts in the second link might be of the most interest to you if you already have longer links. I think those relocation brackets should work. Thanks! Sent from my SAMSUNG-SM-N910A using Tapatalk No problem. I just went through this same situation lol. Those brackets work great. Link to comment Share on other sites More sharing options...
MJCARENA Posted May 21, 2016 Share Posted May 21, 2016 Where is your upper control arm? Link to comment Share on other sites More sharing options...
DirtyComanche Posted May 21, 2016 Share Posted May 21, 2016 Where is your upper control arm? Hmm. I'm hoping it is a wristed radius arm setup or a true 3 link. Some guys have been pulling one upper arm to make a hacktacular 3 link, not really a good idea IMHO. Link to comment Share on other sites More sharing options...
dcramer67 Posted May 22, 2016 Author Share Posted May 22, 2016 Where is your upper control arm?I have the iro long arm kit. It only connects to the upper control arm bracket on the driver side. Sent from my SAMSUNG-SM-N910A using Tapatalk Link to comment Share on other sites More sharing options...
Rockfrog Posted May 24, 2016 Share Posted May 24, 2016 The angle of your sway bar is way out, you need longer sway links, the bar ends should point up about 10-15 degrees, this also helps pull the ends away from the coil. Otherwise a relocation bracket is about all you can do. And I agree, pulling an upper is no way to make a 3link, that just sounds scary. The stock sized upper bushings are definitely not up to that task. The IRO kit is more of a radius arm with only one side tied to the upper correct? So, not really a 3 link anyway, but functional enough I imagine. Sent from my SGH-I337M using Tapatalk Link to comment Share on other sites More sharing options...
dcramer67 Posted May 24, 2016 Author Share Posted May 24, 2016 The angle of your sway bar is way out, you need longer sway links, the bar ends should point up about 10-15 degrees, this also helps pull the ends away from the coil. Otherwise a relocation bracket is about all you can do. And I agree, pulling an upper is no way to make a 3link, that just sounds scary. The stock sized upper bushings are definitely not up to that task. The IRO kit is more of a radius arm with only one side tied to the upper correct? So, not really a 3 link anyway, but functional enough I imagine. Sent from my SGH-I337M using Tapatalk I ordered the relocation brackets. Hopefully that helps the geometry some. Yes, the IRO is basically a radius arm with only one upper. I am not sure why they only use one uppper (more flex?), but I bought the truck with that kit, so I don't know all that much about it. Link to comment Share on other sites More sharing options...
