husky410ohio Posted March 9, 2016 Posted March 9, 2016 I am installing The Yukon free spin kit on my 88 comanche. The kit included the new 5-760X U-joints and outer axle shafts. I cannot use my existing inner axle shafts because they use the smaller 5-260X U-joints. I need the Spicer part number for both driver side and passenger side inner axle shafts for the 5-760X U-joint. I do not use the the CAD so the one piece passenger axle with a new NAPA NOS 11800 seal installed at the differential would be good.
yxmj Posted March 9, 2016 Posted March 9, 2016 You can Goggle it but I am pretty sure you can use 1996 and up XJ shafts....I am pretty sure that is the ujoint used
Incommando Posted March 9, 2016 Posted March 9, 2016 Any shaft that will accept the 297 will accept the 760
schardein Posted March 10, 2016 Posted March 10, 2016 My research showed 96 and up had the 760. U-joint cap diameter is 1.18" vs 1.06" for the smaller u-joint. I decided that was to small to eyeball, so I bought a cheap harbor freight plastic digital measuring caliper to take to the pic-n-pull. Got a set out of a 96 XJ last weekend.
