I was loading my truck up tothis evening at market basket when I noticed an odd knocking/popping noise around the distributor cap. I headed up to my lease and On the way back after dark, my interior lights as well as my headlights got dim and kept getting dimmer. At a red light, my truck would not take anymore throttle after about 1500 rpm. I shifted at low Rpms and got rolling about 40mph. The next red light I couldn't get it to go over 10-15mph. I pulled into oreillys and my truck died. It will not crank. Lights are very dim like I'm getting no power. When you turn the key, you still get the normal fuel pump buzz and a click is all.My battery gauge is at 0. It works Off and on so I can't rely on that. They tested my battery and it showed bad battery but I'm thinking maybe my alternator pulled it down? I have to pull the alternator to have it tested. I've never heard noises like this and first thought it may have been the timing chain. The fuel pump I don't believe would pull my electric power like that. Any input on where to start? Thanks!
Hi kawaboy,
Agree, bad alternator most likely.
Pulling the alternator and having it tested makes the most sense.
If the vehicle is stuck somewhere away from home, you can pull the battery, charge it, and see if you can make it home on that charge.
Your battery is currently dead, but if the alternator is bad, the battery  may just be drained, not defective.
Pull the battery, charge it and test it before condemning it.
Good luck!
Gene
Remove one of the battery cables, loosen the belt, take off the wires and pull it!
It's been about 15 years since I pulled mine so I don't remember any more details....
But do charge and test the battery. A failing alternator can kill a marginal battery, and a failing battery can kill an alternator....So there may be two problems...
Gene
1987 4.0. The voltage meter was on 0 and had been working earlier in the day. When I first noticed the dimming, that gauge had already fallen all the way. Sometimes it's like that but it has been working lately so I figured it was reading correctly
Pull and test alternator. If okay-
Inspect alt and battery cables for intermittent grounding and/or loose/corroded connections. If okay-
Charge battery, start engine and measure battery charging voltage (13.5V-14.5V)  across the posts. If okay-
If battery doesn't hold a charge, have battery tested.
