86 Comanche Troubles! Please HELP!
Okay so I just bought my first Comanche! My dream truck! So obviously I am excited but need some tips... It is a 4 speed with a 2.8 motor.  I drove it home and, had to call a tow truck not to far into the drive after a horrid noise occurred and started over heating.
1. Does anyone have a 2.8 for sale?
2. Is there a motor that will bolt directly up to the trans?
3. Is there any better options for me as far as a swap goes?
--> Any tips are extremely helpful seeing that am not super knowledgeable on Jeeps, more Ford and Chevy
the 3.1 and 3.4 are the ones to look for (mid 90s camaro/firebird or S-10).  it's a better block design and will accept all your accessories/exhaust/intake and bolt to the trans.  only caveats are that your truck has a mechanical pump on the engine block and so you'll need to add in an inline electrical pump and then your current flywheel will need to be neutrally balanced by a shop (the 3.4 is internally balanced but your 2.8 uses the flywheel as the balancing mechanism).
car-part.com can help with junkyard searches
If you're knowledgeable on Chevy, you're in luck.  That POS 2.8L is a GM/Chevy engine.  As mentioned by Pete, if you're in search of a replacement engine, do yourself the favor and scout out a 3.4L from a mid '90s Camaro or Firebird.  It'll be the easiest swap you can do to rid yourself and your MJ of that horrible excuse of an engine.
http://www.lunghd.com/Tech_Articles/Project_XJ/Project_XJ.htm
