Has anyone done a quad shock on an MJ? I am swapping in a Dana 44 out of an Isuzu Rodeo. The shock mounts face rear. I see two holes in the frame, much like the ones the stock mounts go through. Didn't pull those in PA, when I was at a PnP. Only one I saw at 4 PnPs. 2 in PA, 2 in IN.
there's no reason I can see to run any more shocks.  the truck weighs practically nothing.
a photo would help to know what you're looking at. :thumbsup:
"Didn't pull those in PA, when I was at a PnP. Only one I saw at 4 PnPs. 2 in PA, 2 in IN"
Where does one get the decoder ring to figure out what all that means?
Why swap in a 44 out of an Isuzu? Isn't that a 6 bolt wheel pattern?
i believe it's because it will match a waggy front 44 pattern.
Yah it will, I didn't know he was going with a waggy front axle.
Yes Waggy front. PS drop. The Isuzu 44 has the shock mounts on the rear. I might keep them there and mess around. See what I like. Its a light truck so probably over kill, might mess up more than it helps.
 OK Decoder ring : PnP - Pick and Pull
                               PA - Pennsylvania
                               IN - Indiana
