Brand new/bad draglinks?
What's up fellas
So I refreshed my steering on my 98 Xj and was wondering why my steering wheel wouldn't go back to straight even after adjusting it myself and a alignment shop...
Then compared it to the one on my Comanche and it looks bent(prebent) but maybe I thought I bought the wrong part #....
Then bought a wholesale priced one and it's the same as the one on my Xj....
Pic of the one installed
And the new one compared to the one for my Comanche...
Has anyone have this same problem?
I had a problem like that too, only the threads inside the adjuster collar were butting against each other. The solution for me to center the wheel was to re-clock the horn innards. Used the ZJ drag link too and have about the same distance between the thread ends now.
http://comancheclub.com/topic/48200-drag-link-lht-tie-rod-end-question/?hl=steering+wheel
Hmmm...does this work on 97+ Cherokees as well?
I finally got to do a test drive this morning and the steering wheel was straight until I had to make a couple turns to get to my destination...while making those turns I noticed depending on the turn the steering wheel was tilted either to the left or the right and at times it will go back to straight...
