Vulpes Posted January 19, 2016 Posted January 19, 2016 Hello everyone, I'm new here and as of yesterday a proud owner of an '89 Pioneer :) I've got a problem. My front blinkers don't work at all. Rear ones and rear Hazards are fine, but the front is dead. Bulbs are brand new as well. I can't imagine there being a separate fuse of any kind for the front? And the wiring and connections look good from what I can tell by taking out the assembly on the front. Any help would be greatly appreciated, thanks!
lamart72 Posted January 19, 2016 Posted January 19, 2016 Read the topic Cruiser's Mostly Renix Tips in DIY Projects and Tech Writeupshttp://comancheclub.com/topic/48463-cruisers-mostly-renix-tips/ You will find lots of good information there.
buckwheat Posted January 19, 2016 Posted January 19, 2016 cruiser54.com Check it out. Same basic thing as posted about, but I think its organized better.
cruiser54 Posted January 19, 2016 Posted January 19, 2016 cruiser54.com Check it out. Same basic thing as posted about, but I think its organized better. And is always the most current version. Tip 3 covers a connector which could be the root of the original poster's issue.
Strokermjcomanche Posted January 19, 2016 Posted January 19, 2016 If the 10 pin connector doesn't fix your issue more then likely you need new turn signal sockets , had to replace them on a couple trucks .
cruiser54 Posted January 19, 2016 Posted January 19, 2016 If the 10 pin connector doesn't fix your issue more then likely you need new turn signal sockets , had to replace them on a couple trucks . Yup.
a bum with money Posted January 19, 2016 Posted January 19, 2016 assuming were talking about 1157 bulbs,I had this proplem on my 88 when I first bought it. It turned out that the bulb contacts were'nt making contact with the socket contacts after the (push in and turn lock). I didn't buy new pig tails but its on the list. I have no idea how they got that way in the first place. also there was alot of old dried grease that had to be removed too. cheers!
