The car wash killed my comanche
So I have a 1990 4x4 with the 4.0 and a auto it was running great until I took it into the car wash and now the Comanche will not shift out of first. I checked the fuse and got underneath it and found nothing obvious disconnected. Does anyone have any ideas?
Thanks
Well I just unhooked and sprayed down the connectors of the tps, no luck as of yet. I disconnected the fuse to the tcu and it does not allow me to shift manually. Still trying stuff out.
Forgot that.^^^
When my tps went, the first clue was that my aw4 was shifting as though I had the skinny pedal firmly against the floor. It did shift, but only after sitting on the rev limiter for a bit.
When I bought the 98 XJ, thats how the girl drove it....against the rev limiter, changed TPS, all was good.
Did you wash the engine down. I had the same problem on my XJ after cleaning the engine. There is a connector for the trans on the passenger side of the engine that got wet ,and when I took it apart and dried it all was well again.
I just drove it through a automatic car wash in November in Alaska then I shipped the Comanche had it delivered to my door a month later and it did not magically fix it's self for some reason..... I am trying to track down a tcu now, I will look at the plug on the passenger side of the engine now.
