ecu swap (now CPS troubles)
ECUs aren't really known for being a common failure point.  what symptoms are you experiencing?
where do i start?   I found a 90 comanche that has been sitting for who knows how many years, been fixing small things here and there and got it running pretty well.  So i decide to go on a test drive through a trail behind my house and the jeep started stuttering, quit moving then died.  Started working and found i have no spark so i start reading and testing things, long story short i put in a used cps and it ran :-).   Drove back to the garage and shut it down, came out later and it won't start.  NO SPARK! lol  So i have 3 comanche's and the 89 is a parts truck, received a brand new cps this morning and going to try that but was curious if the puter outa the 89 would work.   I have redone all the grounds in the engine compartment, did ohms tests on coil, undid all electrical connections and added di-electric grease.  so i am hoping when i put in the new cps, hope it works.
Well i got the NEW cps installed, turned it over and nothing :-(.     Stuck.   Kinda funny, it will start if i unplug the cps and wait 5-10 min, plug back in it will run for 1-5 secs then abrubtly dies and will not restart.   so i unplug 5-10 min plug back in and it starts  WTH.
*FIXED*  well seems I didn't clean 2 connections, after a friend pointed them out as a possible problem.  It was the 2 connections to the left of the head "i think one grey and one black", one of them was pretty corroded up, cleaned greased and running.  Thankx
Well just as an update, seems when the truck starts to get warm it is still stalling out with no spark.  I have checked power at the coil after it stalls out and continue reading voltage, so I have a new coil I am getting ready to install.  In the lovely snow I might add. :-/
