4DR XJ Rear Door Armrests
I'll try to remember to check the heaps tomorrow. I think one of the MJs has base trim. For the moment, I'm going to guess "Probably not." The front stubby armrests are side-specific, and the part number is different from the XJ rear armrest.
I'll look at my parts pile tomorrow. I think I have the pieces you are asking about, I'll see if its possible. Do you need one of those armrests?
I might if I knew they would bolt up.
Whenever someone says "I'll try to remember", it usually means they won't remember.  :yes:
I did remember to check. Hole spacing is 6-1/4" for both front and rear, as well as for the higher-end front "hockey stick" armrests. But the rear armrests are a bit shorter than the base level front armrests. I suspect if they were used, nobody would ever notice the difference, but it is there.
so.... actually.... my MJ has the tiny arm rests similar to the rear xj rests... from the factory not the medium ones. so i guess its confirmed all 3 came on MJs.
here's the imprint on the doors, showing its from the factory not just thrown on.
here's the part number stamped, its the same for both sides as they seem to be identical
and to confirm buckwheat, here's my spare black medium rests, next to the gray small rests.
