1stDeuce Posted November 10, 2015 Posted November 10, 2015 '86 Jeep Comanche X 4x4 (Longbox) 2.8L / AX-5 (5speed) / NP207 / D30 / D35 w/Factory 4.10 gearing Built September 1985 Original CO truck as far as I know. Location as of 11/2015: Farmington, NM Currently undergoing a "Reman" program in preparation for daily driver status and weekend camping/exploring rig. (Build Thread on ExPo) The 225k mi 2.8L was dying when I bought the truck, so I put a Fuel Injected Camaro 3.4L in it's place. Still running the AX5 for now... I have a NV3550 and NP242 t-case for it eventually, but I'll miss the low reverse gearing of the AX-5. Painted desert sand (Rustoleum!) and interior changed from red to gray, along with some other updates. Running 16x6 steel wheels (From Brazil!) and 235/85R16 Hercules Terra Trac II tires
JMO413 Posted June 28, 2020 Posted June 28, 2020 JP62 *ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ ADA LIGHT PACKAGE AJT RADIO PREP GROUP AJZ BAC 75 AMP ALTERNATOR BCQ Battery - 750 Amp Maintenance Free CGX Head Restraints-Outboard Seating, RR CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CLE ACCESSORY FLOOR MAT - FRONT &&&& REAR DDQ Transmission - 5-Speed Manual EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GPB DUAL - O/S MIRR PKG - LOW MOUNT - CHROME HC0 All Vehicles W/O Air Cond HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LBB COURTESY LAMPS (BELOW PANEL) LMA HALOGEN HEADLAMPS LPE EXTERIOR CARGO LIGHT MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I NAF HIGH ALTITUDE EMISS CONTROL PKG NFA TANK - 20 GAL FUEL NMB ENGINE COOLING - STANDARD DUTY SBA POWER STEERING SUA TILT STEERING COLUMN
