Jackrabbit41 Posted November 3, 2015 Share Posted November 3, 2015 So a while ago I stripped the highest bolt on the diff so I drilled out the hole and tap in a bigger bolt. Well this weekend I didn't like how it looked becuase it was kind of crooked and looked like it didn't go all the way in. so I drilled the hole a little deeper and put new threads in. Well the tap snapped off it there. I've tapped many things before and never had a problem like that. After countless runs to the hardware store, I ended up having to blow it out with the acetylene torch. The whole was then messy from the torch so I heated the housing up to 400 degrees and welded up The hole. Then I started to drill a new hole but my bits wouldn't have it. I then called the shop and they said that it's too hard to drill and they can't do It. What should I do? The guys at the hardware store thought it'd be ok to do that. Should I just load a lot of rtv in there? Thanks and it seems like I'm always making retarded mistakes Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted November 3, 2015 Author Share Posted November 3, 2015 I can get the weld out, but then, what do i do? I tried getting the weld out with the torch and it worked good but I'm left with an ugly deformed hole. I saw some guys just put a nut down in there too. Link to comment Share on other sites More sharing options...
Pete M Posted November 3, 2015 Share Posted November 3, 2015 if it was me, I'd put the cover on as normal and see what happens sans bolt. being the highest bolt, it might not leak at all :D Link to comment Share on other sites More sharing options...
Wiggilez Posted November 3, 2015 Share Posted November 3, 2015 if it was me, I'd put the cover on as normal and see what happens sans bolt. being the highest bolt, it might not leak at all :D that's what I did till I got un-lazy enough to put one in. except mine was closer to the 10-o-clock position Link to comment Share on other sites More sharing options...
Jackrabbit41 Posted November 3, 2015 Author Share Posted November 3, 2015 if it was me, I'd put the cover on as normal and see what happens sans bolt. being the highest bolt, it might not leak at all :D I guess I'll just give it a good helping if rtv Link to comment Share on other sites More sharing options...
Pete M Posted November 3, 2015 Share Posted November 3, 2015 just don't use so much that it squishes into the diff. that could get ugly. Link to comment Share on other sites More sharing options...
