1990 Comanche Posted September 7, 2015 Share Posted September 7, 2015 Will the stock 5-Star 15" wheel fit over a rear disk brake conversion on a Comanche with a Dana 44? Read in some of the posts that factory wheels have clearance problems. Planning on using parts from a ZJ or if you have a better suggestion. Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 7, 2015 Share Posted September 7, 2015 I haven't tried these particular wheels, but I did run into caliper clearance problems originally with the Canyon wheels. A set of 1.25" Spidertrax spacers will fix clearance problems quite easily though, and look better too. Link to comment Share on other sites More sharing options...
Keyav8r Posted September 7, 2015 Share Posted September 7, 2015 I'll second the "looks better" with Spidertrax 1.25" spacers. Can't comment on the clearance issue as I still have drums on the rear. Link to comment Share on other sites More sharing options...
dscowell Posted September 7, 2015 Share Posted September 7, 2015 Some spacer should do the trick or wheels with less back spacing if you want to buy a new set. The wheels on my truck have a 3.25" as opposed to the 5" on my stock wheels and I have no problems. Link to comment Share on other sites More sharing options...
1990 Comanche Posted September 8, 2015 Author Share Posted September 8, 2015 Thanks for all of the answers, but now I have a bigger problem. The Dana 44 I purchased has a bent axle shaft. Anyone have a good source for good used stock shafts? Thanks Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted September 8, 2015 Share Posted September 8, 2015 What spline count ? https://akroncanton.craigslist.org/pts/5204164516.html Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 8, 2015 Share Posted September 8, 2015 Gotta be 30 spline axles. OP, which side (L or R) is bent, and how do you know it's bent? I have a couple of spares. Link to comment Share on other sites More sharing options...
1990 Comanche Posted September 8, 2015 Author Share Posted September 8, 2015 It is the right (long) side. It looked odd, so I put it between 2 V blocks and used a dial indicator. It reads between 0 and 80 as I spin the axle a full 360. Spline is 30 Link to comment Share on other sites More sharing options...
Crash Posted September 8, 2015 Share Posted September 8, 2015 For 44, my understanding is that exploder 8.8 rear discs work best. All will require some kind of mod, since the D44 is a non-c-clip axle. Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 8, 2015 Share Posted September 8, 2015 It is the right (long) side. It looked odd, so I put it between 2 V blocks and used a dial indicator. It reads between 0 and 80 as I spin the axle a full 360. Spline is 30 As in .008 or .080? But if you can eyeball the wobble on a dial indicator, it's bent. I've got the left side axle spares only now. Been waiting for the stockers to snap, so I can swap in the chromoly axle shaft kit I've had for a couple of years. Link to comment Share on other sites More sharing options...
