Comanche won't start
So last weekend I did the ax15 swap, but never actually tried turning it over until today because I was busy with school and my sister was gone so I just drove her Jetta. Everything a on except for the 4wd linkage and front drive shaft. The thing won't start. Battery's good, starters on, it has gas but it was empty when I parked it so I just put 1/4 tank in it. I used the ax15 starter; should I have used the ba10 starter? I don't know much about getting a vehicle started so any help would be great!
Replace the CPS crankshaft position sensor. I wouldn't even bother to ohm it out and play with it. Just replace it as one sure sign is no spark, no fuel. You might have whacked it somehow on the AX-15 swap. I spent almost a year chasing a intermittent bad one as every expert, mechanic, shop says they are never intermittent they just quit on the freeway and you tow it home. They were wrong. One day crank no start. Next day start just fine and run fine. Next day crank no start. Drove me nuts. If I remember correct they are not very expensive but a bit of a task to install. I had a shop with a hoist do it. Easier to do when your standing up. Worth a try.
