Paul Bruchal Posted August 25, 2015 Share Posted August 25, 2015 My driver side tail light works fine. My passenger tail light only lights up when the headlights are on. The Front turn signal on the passenger side works too. The only thing is the passenger tail light blinker and brakes don't work, all lights are fine. I replaced all the bulbs and flasher relay that's next to the fuse panel. Before the front passenger didn't work either but replacing the replay made the front work too. I am very confused. When I went to replace the stereo, their was a rats nest of crappy wiring job that was done and wasn't even necessary. Their is another crappy wiring job for the trailer light connector too stuffed into the rear bumper. I'm thinking my problem is the trailer harness wiring. Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted August 25, 2015 Share Posted August 25, 2015 I'm thinking my problem is the trailer harness wiring. Remove that and report back. Link to comment Share on other sites More sharing options...
reubj Posted August 25, 2015 Share Posted August 25, 2015 I had a similar problem and it was from a trailer wiring job done by the previous owner. Clean that up and check the factory harness connector under the bed just behind the gas tank. Mine was very corroded and contributed to the problem. Link to comment Share on other sites More sharing options...
Pete M Posted August 25, 2015 Share Posted August 25, 2015 I had a similar problem and it was from a trailer wiring job done by the previous owner. Clean that up and check the factory harness connector under the bed just behind the gas tank. Mine was very corroded and contributed to the problem. x2. that connector was bad in my 88. :( Link to comment Share on other sites More sharing options...
Steve Gregory Posted August 26, 2015 Share Posted August 26, 2015 I had a similar problem and it was from a trailer wiring job done by the previous owner. Clean that up and check the factory harness connector under the bed just behind the gas tank. Mine was very corroded and contributed to the problem. x2. that connector was bad in my 88. :( x3 Had to replace that harness in my 89 Link to comment Share on other sites More sharing options...
Paul Bruchal Posted August 26, 2015 Author Share Posted August 26, 2015 Thanks for the input! I will try to remove the wiring and reconnect the wires back to factory locations this weekend. And Ill report back lol Link to comment Share on other sites More sharing options...
