Should I take this ax15?
  The input shaft is pretty rusty, seems to indicate the trans was sitting outside with a hole in the top (no shift lever).  As you mentioned it's also missing the bellhousing & front bearing retainer. I'd pass on it.
  Have you tried one of the "big box" junkyards?  LKQ has a deal with Advance and they'll ship used parts to the local Advance parts store. Pricing was ok but not great the last time I used them.
  I found an external slave 4WD AX15 at the pull-a-part last spring but I had been keeping an eye out for quite some time.  If there's a U-pull-it junkyard nearby it would be worth the time to look around.
