Working on getting this 91 back up to running status. Dropped the tank to check for debris, and replaced the fuel filter. That helped the starting issue, but now it's got a low, stumbling idle. Is this a TPS issue, or a fuel issue? I can hear the pump turn on and prime so I don't think the issue is there.
no , the HO requires a higher psi I think , somewhere between 45-49 psi , hopefully someone can chime in to confirm this
I thought I had read that, but can't find any source for it.
When they went to the returnless fuel injection system, the pressures were higher spec. comanche was discontinued years before that.
