86 chomanche upgrade Posted May 26, 2015 Posted May 26, 2015 86 Comanche 4x4 2.5 what other motors will fit n this truck I'm putting a lift on it big tires and il need more power may change trans and case what will fit motor wise what have yall used
86 chomanche upgrade Posted May 26, 2015 Author Posted May 26, 2015 what all have u had to change my 86 is a 4 speed which I probably go to a 5 speed
Eagle Posted May 26, 2015 Posted May 26, 2015 It depends on what you mean by "fit," and how much work and fabrication you want to do. THe direct fir options are another AMC/Jeep/Chrysler 2.5L, an AMC or GM 2.8L V6 (not a good choice), or a 3.1L or 3.4L GM V-6 out of a rear-wheel drive car like a Firebird or Camaro. Beyond that, it's adapters and fabrication for the win.
86 chomanche upgrade Posted May 26, 2015 Author Posted May 26, 2015 3.1 and 3.4 bolt up same motor mounts not really wanting to do a ton of fab putting it on 35s w 4.5 inch lift change n gears just need extra power for mud hunting it 4x4 am I gunna b able to find a 5 speed for one of them motors
dasbulliwagen Posted May 27, 2015 Posted May 27, 2015 Buy a 4.0 XJ donor complete and swap it all over. You'll need to cut and weld the core support to swap the rad and maybe massage the firewall s little but I think that's your best option for power reliability and cost with minimal fabrication. All you'll need made up is a rear driveshaft.
