Anyone have LCG MJ pics?
33s will fit in the rear, but depending on tires width and wheel backspacing you may have trouble up front. I briefly ran 4.5" with 33x12.50 and had problems keeping them out of the front fenders. I ended up adding 1.75" spacers up front and going SOA in the rear and it all fit fine.
3.5" will be a challenge, but might be doable with 33x10.50 tires. My daughter's ran 265/75R16s which equal out to about a 32x10.50 on 2.75" lift without too much of a problem, and no problem at all at 4.5" now. I used stock KJ Liberty 16" rims and WJ Grand Cherokee lower control arms on it.
My truck now sits on full width tons and low backspacing double beadlocks with 37s on the same 6.25" lift, but the custom bracketry on the front axle actually added one more inch to the front ride height. Very stable with the 85" track width and heavy axle/tire combo underneath.
https://www.facebook.com/video.php?v=10202508738173291&set=t.100001137240661&type=3&theater
882313_10202503441400875_216447643262756
