Zebvance Posted April 15, 2015 Share Posted April 15, 2015 http://www.fourwheeler.com/how-to/transmission-drivetrain/131-1107-how-axle-gears-work/photo-10.html according to this a LP is stronger........ Just so every one doesn't have to click the link here is the quote: In a low-pinion axle (right) the pinion drives on the stronger, drive side of the ring gear teeth when used in a rear axle application, but on the weaker, coast side when used as a front axle. The high-pinion (reverse cut) axle (left) and gearset applies pressure to the drive side of the gear teeth when used as a front axle, but to the weaker coast side when used as a rear axle. From: http://www.fourwheeler.com/how-to/transmission-drivetrain/131-1107-how-axle-gears-work/photo-10.html#ixzz3XPPooP80 Follow us: @fwmag on Twitter | fourwheelermag on Facebook way to rub it in.. lol Link to comment Share on other sites More sharing options...
Incommando Posted April 15, 2015 Share Posted April 15, 2015 http://www.fourwheeler.com/how-to/transmission-drivetrain/131-1107-how-axle-gears-work/photo-10.html according to this a LP is stronger........ Just so every one doesn't have to click the link here is the quote: In a low-pinion axle (right) the pinion drives on the stronger, drive side of the ring gear teeth when used in a rear axle application, but on the weaker, coast side when used as a front axle. The high-pinion (reverse cut) axle (left) and gearset applies pressure to the drive side of the gear teeth when used as a front axle, but to the weaker coast side when used as a rear axle. From: http://www.fourwheeler.com/how-to/transmission-drivetrain/131-1107-how-axle-gears-work/photo-10.html#ixzz3XPPooP80 Follow us: @fwmag on Twitter | fourwheelermag on Facebook way to rub it in.. lol Nah...I like to put the stuff in the post and also add the clicky. The folks who don't want to do the whole clicky thing don't have to but those who want to can. Link to comment Share on other sites More sharing options...
