Dis Posted April 7, 2015 Posted April 7, 2015 Hey guys I am New here i am now the proud owner of a 1990 4.0l renix thanks to the other forums regarding this, I am 95% complete. I am in the process of swapping out my idiot gauges for a full panel, i have only one issue so far and that is the part number for coolant temperature sending unit. I bought one from autozone its part number is tu108, however i do not know if that is for an idiot switch or for the temperature gauge, if someone has a part number it would be awesome. thanks Dis i have almost every major auto part store near by i prefer, oreillys or autozone(only bc they had it in stock)
Dom U Posted April 7, 2015 Posted April 7, 2015 http://m.napaonline.com/parts/PartsDetail.aspx?k=ECHTS6053_0193389554temperature switch. As For the oil switch only place I was able to find it was on rockauto.
Dis Posted April 7, 2015 Author Posted April 7, 2015 Btw Thanks to rubiconron for showing the upgrade on the cluster, i Will Post Some PIcs on how i modified my new Cluster Vs The old one, the adaption took me about 10 extra mins but i have to Break it down again, due to i wanted to make sure the speedometer worked. It did, fyi the donor vehicle was in junk yard it was a 1991 xj, it was literally pug in play, except for the modification and oil pressure.sending unit.
wvzj Posted April 7, 2015 Posted April 7, 2015 I bought one from autozone its part number is tu108, however i do not know if that is for an idiot switch or for the temperature gauge, if someone has a part number it would be awesome. thanks Dis i have almost every major auto part store near by i prefer, oreillys or autozone(only bc they had it in stock) That is the correct sensor for the gauge
Eagle Posted April 7, 2015 Posted April 7, 2015 I bought one from autozone its part number is tu108, however i do not know if that is for an idiot switch or for the temperature gauge, if someone has a part number it would be awesome. thanks Dis i have almost every major auto part store near by i prefer, oreillys or autozone(only bc they had it in stock) That is the correct sensor for the gauge No, it's not. Autozone part #TU108 clearly states that it is a coolant temperature "switch." That's for use with idiot lights. The listing also has a "related parts" area that includes "Coolant temperature sensor" http://www.autozone.com/engine-management/temperature-switch?filterByKeyWord=TU108&fromString=search&isSearchByPartNumber=true Problem is, if you click the link to the related "coolant temperature sensor," it shows one with a pigtail and it says it fits the thermostat housing. That's not the correct part for a Renix, that would be for an HO. In other words, Autozone (as usual) doesn't have a clue. This one, from Advance, looks to be the right one: http://shop.advanceautoparts.com/p/bwd-engine-coolant-temperature-sender-wt761/5973805-P
wvzj Posted April 8, 2015 Posted April 8, 2015 I bought one from autozone its part number is tu108, however i do not know if that is for an idiot switch or for the temperature gauge, if someone has a part number it would be awesome. thanks Dis i have almost every major auto part store near by i prefer, oreillys or autozone(only bc they had it in stock)That is the correct sensor for the gaugeNo, it's not. Autozone part #TU108 clearly states that it is a coolant temperature "switch." That's for use with idiot lights. The listing also has a "related parts" area that includes "Coolant temperature sensor"http://www.autozone.com/engine-management/temperature-switch?filterByKeyWord=TU108&fromString=search&isSearchByPartNumber=trueProblem is, if you click the link to the related "coolant temperature sensor," it shows one with a pigtail and it says it fits the thermostat housing. That's not the correct part for a Renix, that would be for an HO. In other words, Autozone (as usual) doesn't have a clue.This one, from Advance, looks to be the right one:http://shop.advanceautoparts.com/p/bwd-engine-coolant-temperature-sender-wt761/5973805-P If you cross TU108 and WT761 they are the exact same, just different manufacturers. They both cross to Napa 6053 which is the one I used and was previously mentioned by Dom. So yes TU108 will work
HOrnbrod Posted April 8, 2015 Posted April 8, 2015 So yes TU108 will work. Yep. Using the same sender. The Zone calls it a switch on their site but it's not.
Dis Posted April 13, 2015 Author Posted April 13, 2015 Yes this renix coolant sending unit TU108 did work just fine (note it was a 1/2 deep socket and the original was 13mm deep socket) fyi the oil sending unit was PS133 part numbers are from Autozone.
Dis Posted April 13, 2015 Author Posted April 13, 2015 Just in case anyone needs reference http://comancheclub.com/topic/4356-gauge-swap-little-help-please/(will help with the changes for sensors/cluster) and http://comancheclub.com/topic/14086-upgrading-to-a-gauge-package-w-column-shifter/?hl=gauge (will help with the PRND21 indicator)
