Dis
Everything posted by Dis
  1. http://www.govplanet.com/jsp/s/item/677384?kwtag=p13n-V&h=anotherone in wa starting at 900 and its 4x4 aswell with 102.5 k
  2. Sorry, Pioneer , I mean, was taking apart the trim/door panels to wire in new speakers. And on the trim it said cheif, and it was about midnight when I posted that. So I wasn't firing on all cylinders. But I did look at the link hornbrod linked. I wasnt able to get an of the links to work.
  3. No it doesnt, i don't plan on adding it, may add it in the future, but if i do i will use an aftermarket alarm to unlock the doors.
  4. I have a 1990 chief , i am trying to add an Overhead console from a 1990 xj i have the console and the mounting brackets and the wiring from the donor vehicle , my problem is the wiring, I have not been able to find a write up for this, involving an MJ. have no problem having to modify the harness, and electrical work does not scare me. It does appear i do have the ambient sensor temp in the middle of my bumper. i would like ambient temp to work, as i do live in Texas. if someone could post a link or so or even pictures on how they did i would be very grateful.
  5. Not mine he has has this up for awhile http://austin.craigslist.org/cto/4967595051.html
  6. sent a pm if your still looking
  7. Just in case anyone needs reference http://comancheclub.com/topic/4356-gauge-swap-little-help-please/(will help with the changes for sensors/cluster) and http://comancheclub.com/topic/14086-upgrading-to-a-gauge-package-w-column-shifter/?hl=gauge (will help with the PRND21 indicator)
  8. Just in case anyone needs this http://comancheclub.com/topic/14086-upgrading-to-a-gauge-package-w-column-shifter/?hl=gauge, will help you with the PRND21 indicator
  9. Yes this renix coolant sending unit TU108 did work just fine (note it was a 1/2 deep socket and the original was 13mm deep socket) fyi the oil sending unit was PS133 part numbers are from Autozone.
  10. Btw Thanks to rubiconron for showing the upgrade on the cluster, i Will Post Some PIcs on how i modified my new Cluster Vs The old one, the adaption took me about 10 extra mins but i have to Break it down again, due to i wanted to make sure the speedometer worked. It did, fyi the donor vehicle was in junk yard it was a 1991 xj, it was literally pug in play, except for the modification and oil pressure.sending unit.
  11. Hey guys I am New here i am now the proud owner of a 1990 4.0l renix thanks to the other forums regarding this, I am 95% complete. I am in the process of swapping out my idiot gauges for a full panel, i have only one issue so far and that is the part number for coolant temperature sending unit. I bought one from autozone its part number is tu108, however i do not know if that is for an idiot switch or for the temperature gauge, if someone has a part number it would be awesome. thanks Dis i have almost every major auto part store near by i prefer, oreillys or autozone(only bc they had it in stock)
