Adjustable control arm question.
I have fixed OEM style control arms now.
During the original install of the axle and the last two times I've had it disconnected, I could get the two uppers bolted and one lower bolted easily but the last bolt of the lower was a b*@$£. When I installed new springs several weeks ago I noticed that the upper driver's side bushing looked like it has be stressed, worn. I'm assuming that the two uppers are out of alignment.
Question is-
When I install the adjustables, do I adjust the upper to each mount or do I make certain that each arm is the same length and then use the ratchet strap on the last bolt?
Thanks
Yeah, both.
I'm considering Ironman's arms. Two reasons- the WJ hits the shock mount and I want to move the axle out about 1/2" to center the wheel before I go 285/60/18.
And.....I'm moving the lowers and Ravines over to the XJ.
3" of lift.
Static-
Image Not Found
Which side / angle / is this pic taken from? Let me know and I'll snap a pic. I just looked at mine and have over 1/2" clearance between the lower shock mount and the top of the LCA, and the wheel is perfectly centered in the flare.  Something's not right..........
EDIT:  Quick Pic
I took out 1/8" of shim from each side today and that seemed to help a little.  Steering got a little better.
Could be my caster is way off.
After the arms are installed, there is a good shop local to me and the guy is good with Jeep and he understands the suspension, I'll have him align it.
Just for reference, I have installed WJ lowers and I'm currently working on installing WJ uppers. I had to trim the shock mount because the WJ uppers are slightly shorter. This means that the shock mount was pushing on the WJ lowers at full droop. I will take a picture of how much I removed once I get my axle side bolts in ( It's been a pain so far).
I have a 225/75/16 tire with 1 3/4'' of lift. WIth 245 or 255's your axle would be up higher, so with a bigger tire there is less to worry about.
Jeep Driver, maybe it's just camera angle, but it looks as though you have the WJ LCAs installed upside down. The round bushing is supposed to be in front; oval bushing on the rear. That would explain the tight clearance with the shock mount.
Someone eyeball this and tell me I'm crazy.................
This is what I pulled off the web, but my crown manual shows the same diagram.
Another image: http://image.fourwheeler.com/f/39375960+w660+h440+q80+re0+cr1+ar0/1202-4wd-03%2b1999-jeep-grand-cherokee-wj-rough-country-suspension%2bcontrol-arm
Seems to me that the round bushing should be on the frame side. If the arms were reversed, you'd have less ground clearance. Though at the same time, you'd have an easier time clearing the shock mount.
Edit, see post number four: http://www.cherokeeforum.com/f67/wj-control-arms-xj-direction-130408/
Thanks Dillithium. It appears mine are mounted upside down, opposite of the factory WJ mounting, not Jeep Driver. Well, they have been on there like that for many years and work just fine and the bushings are fine too. Wondered why I didn't have to trim anything except the bushing sleeves when I mounted them. I'll swap them around when I change bushings in ten years or so...... :yes:
From the WJ parts manual:
Thanks guys.
The first WJ set I put on were take offs from the PnP and I put them on the way I took them off.
I'm convinced that I have an alignment problem, everything sort of changed after I installed the new ball joints. One of my ball joint came out in pieces and the alignment was to the old lowers and ball joints.....IOWs I changed too much after the last alignment.
