drase Posted April 2, 2015 Share Posted April 2, 2015 I have a 2WD, 6 cyl, auto, 87 MJ. I have vibration above 40+ mph only why I'm accelerating. If I let off the gas the vibration stops. Does this sound like a driveshaft u joint problem more than axle? On a 2WD truck how many axle u joints are there? Just 2, which are on the front? Link to comment Share on other sites More sharing options...
Dillithium Posted April 2, 2015 Share Posted April 2, 2015 Yes, 2 u joints. But in your driveshaft, not front axle. You have a front axle without axle shafts, so no u joints to worry about. How are your motor and tranny mounts? Link to comment Share on other sites More sharing options...
Blue XJ Posted April 2, 2015 Share Posted April 2, 2015 Sounds u-joint related to me, probably the one down by the rear axle, but I would replace both of them on the driveshaft. Link to comment Share on other sites More sharing options...
drase Posted April 2, 2015 Author Share Posted April 2, 2015 Yes, 2 u joints. But in your driveshaft, not front axle. You have a front axle without axle shafts, so no u joints to worry about. How are your motor and tranny mounts? Awww, thanks for the info. I think the mounts are ok, I'll check them out. Link to comment Share on other sites More sharing options...
drase Posted April 7, 2015 Author Share Posted April 7, 2015 UPDATE: It was the driveshaft U-joints. Replaced both and no more vibration!! :banana: Link to comment Share on other sites More sharing options...
metrictonner Posted April 8, 2015 Share Posted April 8, 2015 Some manufacturers actually sell unbalanced brake drums that can cause rear axle vibration. When you brake with these turkeys it vibrates more. Link to comment Share on other sites More sharing options...
gogmorgo Posted April 8, 2015 Share Posted April 8, 2015 An unbalanced brake drum would cause vibration all the time, like an unbalanced wheel or tire, would it not? Link to comment Share on other sites More sharing options...
Marine1Texas Posted April 10, 2015 Share Posted April 10, 2015 yes it would, however would be come worse during braking. Link to comment Share on other sites More sharing options...
