Dom U Posted March 21, 2015 Share Posted March 21, 2015 Hello I need to replace both my headlights there in horrid condition. I'm looking for plug n play. How ever I don't mind swapping out a harness if its worth it. Just wanted some opinions on what you all like. Also is there anywhere that sells the weather stripping for our doors? Link to comment Share on other sites More sharing options...
cruiser54 Posted March 21, 2015 Share Posted March 21, 2015 Do the harness for sure. Some replacement halogens will be fine. Link to comment Share on other sites More sharing options...
benjy_26 Posted March 21, 2015 Share Posted March 21, 2015 I made my own harness using some 10ga wire and a pair of 30 amp relays. I was astonished at the difference in light output between the upgraded wiring and the stock one, even when running stock style halogens. Link to comment Share on other sites More sharing options...
cruiser54 Posted March 21, 2015 Share Posted March 21, 2015 Correct. I wish I had saved the test results from another post on another forum. A guy used some sort of a meter and determined that with JUST the harness, the light output increased over 35%. Link to comment Share on other sites More sharing options...
Pete M Posted March 21, 2015 Share Posted March 21, 2015 late model XJ door seals are a great upgrade over the stockers. they are thicker, seal better and are in much better condition in the junkyards. Link to comment Share on other sites More sharing options...
Dom U Posted March 21, 2015 Author Share Posted March 21, 2015 Correct. I wish I had saved the test results from another post on another forum. A guy used some sort of a meter and determined that with JUST the harness, the light output increased over 35%. 35% that's pretty impressive. Link to comment Share on other sites More sharing options...
Dom U Posted March 21, 2015 Author Share Posted March 21, 2015 late model XJ door seals are a great upgrade over the stockers. they are thicker, seal better and are in much better condition in the junkyards. Alrighty thank you. So u know if anyone sells new ones? Believe it or now yards around me hardly get XJs anymore :/ Link to comment Share on other sites More sharing options...
cruiser54 Posted March 21, 2015 Share Posted March 21, 2015 Correct. I wish I had saved the test results from another post on another forum. A guy used some sort of a meter and determined that with JUST the harness, the light output increased over 35%. 35% that's pretty impressive. I knew it was a lot having done it on my wife's 88 XJ. It was kind of cool to have it backed up scientifically. Link to comment Share on other sites More sharing options...
Pete M Posted March 21, 2015 Share Posted March 21, 2015 late model XJ door seals are a great upgrade over the stockers. they are thicker, seal better and are in much better condition in the junkyards.Alrighty thank you. So u know if anyone sells new ones? Believe it or now yards around me hardly get XJs anymore :/ http://teamcherokee.com/door-opening-seal-jeep-cherokee-1997-2001/ and car-part.com can help you find junkyards with XJs. Link to comment Share on other sites More sharing options...
az comanches Posted March 21, 2015 Share Posted March 21, 2015 You can get the weatherstrips on e-bay, am-autoparts. Link to comment Share on other sites More sharing options...
Lee21490 Posted March 22, 2015 Share Posted March 22, 2015 late model XJ door seals are a great upgrade over the stockers. they are thicker, seal better and are in much better condition in the junkyards.Alrighty thank you. So u know if anyone sells new ones? Believe it or now yards around me hardly get XJs anymore :/ http://teamcherokee.com/door-opening-seal-jeep-cherokee-1997-2001/ and car-part.com can help you find junkyards with XJs. Ordered a set, THanks. Link to comment Share on other sites More sharing options...
