So just put a ax15 back in to my mj 2 weeks ago everything got torqued properly an all was fine till today. Started it drove for like 2 miles then when I'd press the clutch it'd make a terrible grinding screeching sound. So I get under it every bolt holding Trans to block was 1/4 OF THE WAY UNDONE. Any ideas wtf is going on. I tightened it back up an it's good now. This confuses me
Maybe you should have used loc-tite? Not sure if those particular bolts require it or not. I assume the vibration of use made them back out. What about torque specs? were they torqued properly?
Do you have the locating dowels in place? If not, the bell housing might be able to shift enough to start loosening the bolts.
