warf90 Posted May 27, 2007 Share Posted May 27, 2007 I am thinking about buying new wheels when I upgrade from my 33" to 35" tires. I am going with an 8" rim. What back spacing should I go with? Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted May 27, 2007 Share Posted May 27, 2007 A 12.5 inch wide TIRE is hard to fit under the fenders with any reg BS'd rim. This is why many guys go with 10.5 wide tire and a rim with 4" of BS. While 4.5" BS even fits better, but is not avalible as a std size in BS. CW Link to comment Share on other sites More sharing options...
warf90 Posted May 27, 2007 Author Share Posted May 27, 2007 I am going to get 35X12.50. I have never really liked the look of the 10.50 tires. I want to try and find a set of plain steel wheels like this one. I am sure that I would have to order it with the size I want. Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted May 27, 2007 Share Posted May 27, 2007 To each his own...thats what makes the world go round. Good luck with it!! CW Link to comment Share on other sites More sharing options...
DirtyComanche Posted May 27, 2007 Share Posted May 27, 2007 If ya got 7" of lift, most would go with about a 3-3.5 BS. Personally I'd go 2". You'll be doing some trimming. Link to comment Share on other sites More sharing options...
johngus Posted May 28, 2007 Share Posted May 28, 2007 I've got 35 x 12.50 with a 4.75 backspacing. They rub the LCA's a little at full lock, but I am able to run stock flares. Also my rims are 15 X 8's. Link to comment Share on other sites More sharing options...
tjbliley Posted May 28, 2007 Share Posted May 28, 2007 Check on Summit for the rims. You can pick the width, diameter, BS and offset, as well as bolt pattern. They are not too much $$$ either. Link to comment Share on other sites More sharing options...
