schardein Posted February 22, 2015 Share Posted February 22, 2015 Made a run to the pick-n-pull and scored some headlight delay modules (part # 8956000636). $16 shipped. I've got three of these, original mounting screw included. Link to comment Share on other sites More sharing options...
88cpc Posted March 24, 2015 Share Posted March 24, 2015 What do these do? Just curious. Link to comment Share on other sites More sharing options...
schardein Posted March 25, 2015 Author Share Posted March 25, 2015 If you leave your headlights on, then shut off the ignition, then shut off the headlights, they stay on for 45-60 seconds, then shut off automatically. Shut headlights off first and its normal, they are just off. Plug and play, all MJ/XJ are wired for them. Link to comment Share on other sites More sharing options...
Minuit Posted March 29, 2015 Share Posted March 29, 2015 Yep. Pretty handy if your house doesn't have many outside lights. 5 minutes to install max, plugs right in. Link to comment Share on other sites More sharing options...
Guest Posted March 29, 2015 Share Posted March 29, 2015 Hello, first post on the forums, where do these install? Wheres the plug for this located? Would be a nice feature to have. Thanks, Brian Link to comment Share on other sites More sharing options...
jeepsouth Posted March 29, 2015 Share Posted March 29, 2015 It is a nice feature. I added it to my truck too. Link to comment Share on other sites More sharing options...
Minuit Posted March 30, 2015 Share Posted March 30, 2015 Hello, first post on the forums, where do these install? Wheres the plug for this located? Would be a nice feature to have. Thanks, Brian There should be a plug under the drivers side of the dash. It'll have a little bump in the middle on top of it just like the module.It screws into the lower dash panel. Link to comment Share on other sites More sharing options...
schardein Posted April 2, 2015 Author Share Posted April 2, 2015 It's already been covered, but they mount under the dash just to the drivers side of the steering column. While you could just plug it in and tuck it under the dash, it should be screwed to the metal support that is covered by the lower dash valance. Proper installation (factory) would most likely involve removing the lower valance for access. At least, I've never been able to use the factory screw in the factory hole without doing so. Others may have different tools or better flexibility! However, still a pretty easy install. I'll see if I can find a pic of installation with the valance removed for access. Link to comment Share on other sites More sharing options...
fiatslug87 Posted April 3, 2015 Share Posted April 3, 2015 Here you go Link to comment Share on other sites More sharing options...
schardein Posted April 4, 2015 Author Share Posted April 4, 2015 Thank you! :agree: Link to comment Share on other sites More sharing options...
schardein Posted April 29, 2015 Author Share Posted April 29, 2015 Still got some of these. Link to comment Share on other sites More sharing options...
schardein Posted June 14, 2015 Author Share Posted June 14, 2015 Bump Link to comment Share on other sites More sharing options...
schardein Posted September 2, 2015 Author Share Posted September 2, 2015 Bump Link to comment Share on other sites More sharing options...
schardein Posted November 29, 2015 Author Share Posted November 29, 2015 Still available Link to comment Share on other sites More sharing options...
Archived
