Vent window lower steel trim?
The metal frame of the vent window is shaped like a #4 with the side going down into the door as a track for the roll up window. You need to replace the entire fame but it's really easy. I would swap in the solid ones to avoid the usual leaks common with the pivot wing windows.
  • 3 months later...
Me, too.
I have an XJ with wings and MJ without. I'll take "without".
