Battery tray
Tray just broke and need a new one. The comanche has such a weird tray that I was wondering if anyone found a good replacement that is not made of plastic. Or did most of you just make your own? Thanks.
The XJ tray is plentiful and is the same.
:agree:  I pulled mine from a junkyard complete with hardware for a little over 10.00. Be very careful and DO NOT OVER TIGHTEN.
So got this message a little late.... Yep busted off one of the nuts and bolt. Can I still do it with 2 screw instead of three? Or should I just drill a new hole? How should I proceed on  this. I feel like I always have to learn the hard way.... LOL. The one that busted was the front one. The two in the back are still good. Advice?  :brows:
