2.5l tbi question
6mm is an incomplete thread size and would mostly be useless. All it gives you is the nominal diameter of the shaft. It doesn't specify thread pitch, which could be the common coarse (1.0) or fine (0.75), or any non-standard pitch.
Maybe in the Great White North but here in the US you will get 6x1.0   Other pitches don't come in until you get to 8mm
Metric Thread Pitch With thanks to boltdepot.com
Bolt Diameter Standard Thread Pitch (mm) Fine Thread Pitch (mm) Extra Fine Thread Pitch (mm) 4mm 0.70 - - 5mm 0.80 - - 6mm 1.00 - - 7mm 1.00 - - 8mm 1.25 1.00 - 10mm 1.50 1.25 1.00 12mm 1.75 1.50 1.25 14mm 2.00 1.50 - 16mm 2.00 - - 18mm 2.50 - - 20mm 2.50 - - 24mm 3.00 - - Size Identification: Metric bolts are written down as an "M" followed by 3 numbers. For example M10x1.25x35 The first number is the diameter, the second the thread pitch, and the third the length all in millimeters. The example is therefore a 10mm diameter fine thread bolt 35mm long. Thread pitch: The distance from one thread to the next, measured down the length of the fastener.
Well, that didn't work out.\
http://www.raygirling.com/metthrpt.htm
