ORCA Posted May 23, 2007 Share Posted May 23, 2007 So I removed the pinstripping off the truck today and now there's lines of goo in place of the stripes. Would WD-40 work? Would it be safe to use on the paint? Any other solutions? Link to comment Share on other sites More sharing options...
tjbliley Posted May 23, 2007 Share Posted May 23, 2007 use 'goo-gone' it works great with a scrubber sponge. Link to comment Share on other sites More sharing options...
feerocknok Posted May 23, 2007 Share Posted May 23, 2007 Yay, goo-gone! Link to comment Share on other sites More sharing options...
ORCA Posted May 23, 2007 Author Share Posted May 23, 2007 It won't hurt the paint? Link to comment Share on other sites More sharing options...
UNL1MTD Posted May 23, 2007 Share Posted May 23, 2007 It won't hurt the paint? I've used it on mine and it hasnt hurt the paint yet. Now me scrubbin it mindless has introduced some scratches. Link to comment Share on other sites More sharing options...
ORCA Posted May 23, 2007 Author Share Posted May 23, 2007 hahah 10-4. Thanks for the input Link to comment Share on other sites More sharing options...
87manche Posted May 23, 2007 Share Posted May 23, 2007 it will strip off any kind of wax that was on the paint. So after googone you need to put a few coats of wax on it to protect the paint. I'd also recommend an "eraser wheel" FOund at the local body shop. It's a rubber wheel, chuck it in the drill and it will take the stickers right off. Link to comment Share on other sites More sharing options...
89eliminator Posted May 24, 2007 Share Posted May 24, 2007 the eraser wheel that 87manche is talking about is the best option in my opinion. it doens't wreck the paint and it is fairly quick. Link to comment Share on other sites More sharing options...
erthmun Posted May 24, 2007 Share Posted May 24, 2007 Hi all ! New to this forum, but not to Jeeps. I just picked up a '89 Comanche, repainted some time in its life in a slate gray (bad job) and was pinstriped with this Gawdawful fuscia (?) pinstipes. Spent 2 days using fingernails to pull and pick off only to have that described residue left on mine. Not worrying about the condition of the paint, I used what we use at my friends pawn shop when getting sticker goo off items. Zippo lighter fluid. Works great and I think it's cheaper than Goo Gone..... erthmun Link to comment Share on other sites More sharing options...
UNL1MTD Posted May 24, 2007 Share Posted May 24, 2007 I just ordered an eraser wheel w/ arbor for 15 bucks. I'll report back once it comes in and I get a chance to try it out. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted May 24, 2007 Share Posted May 24, 2007 heat gun, goo gone, and plenty of rags. 20 min. tops to get it all on one side. Link to comment Share on other sites More sharing options...
UNL1MTD Posted May 24, 2007 Share Posted May 24, 2007 heat gun, goo gone, and plenty of rags. 20 min. tops to get it all on one side. bs or maybe I just really stink at it. But using all that I spent an easy 4 hrs doing one side of mine. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted May 24, 2007 Share Posted May 24, 2007 i have a certified heat gun, not a hair dryer..it gets hotter and pulls up the decals better. trick with the goo gone is to wipe once or twice with one rag, and then get a new rag...otherwise it leaves even more residue. Link to comment Share on other sites More sharing options...
Red Dog Posted May 26, 2007 Share Posted May 26, 2007 Body Shop guy turned me on to these two 3M products. 1st, 3M Wood Grian Panel / Decal Remover Aerosol Spray. 2nd, 3M Adhesive Remover. Comes in a Red and White Square can. If you follow instructions on the products, you can take off any decal or stripe while doing absolutely no damage to the paint. My problem was, the paint under the Sportruck Stripe was in factory condition, and the surronding paint was still 10 years old. :roll: Link to comment Share on other sites More sharing options...
once red Posted May 28, 2007 Share Posted May 28, 2007 I used NAPA'S Decal spray remover, very succesdsfully on my last Eliminator. Now I need another one to finish the can. :popcorn: Link to comment Share on other sites More sharing options...
UNL1MTD Posted June 6, 2007 Share Posted June 6, 2007 Sorry to dig up a thread from the dead, but I figured I should follow up. I got my decal remover in the mail the other day and I've finished stripping the other side. This thing is basically a rubber wheel with an arbor on it to put it into a drill. You got to keep the drill on a slow speed and it helps to have an additional handle on it to keep it steady. Too fast of a speed and you'll burn the paint or go straight through to the primer. That said, this thing is pretty awesome. Put it into the drill and it just wipes off the decals. Did all of my sportruck on the driver's side in about 1.5hrs. I know its no 20 minutes, but it took off the goo to, so all I needed to do was give it a quick spray and wipe. I'm really impressed with the thing and it was only 15 bucks. Plus you get to use a power tool...always a bonus. It leaves no marks whatsoever on the finish. In comparison to the passenger side I did with just goo gone, the driver's side is much better. There is a touch of residue on the pass side, which I'm going to go over with the wheel when I get a chance. Link to comment Share on other sites More sharing options...
tjbliley Posted June 6, 2007 Share Posted June 6, 2007 Where did you get this remover? I am in need of one to get rid of my pioneer stripes. I would love to get one myself. Can you post your source please? Link to comment Share on other sites More sharing options...
UNL1MTD Posted June 6, 2007 Share Posted June 6, 2007 Where did you get this remover? I am in need of one to get rid of my pioneer stripes. I would love to get one myself. Can you post your source please? I bought mine from Monstronix. Brand Name : SG Tool Aid Model Number : SGT17900 Product Desc : Autobody Eraser Wheel with Arbor Quantity : 1 Price/Unit : 12.2737 They tacked on a lot for shipping though, right at 20 bucks total. I never tried to source one locally. Link to comment Share on other sites More sharing options...
