How can I tell what gears I have?
 jack up one rear tire, put the trans/tcase in neutral, rotate the raised tire around twice while counting the times the driveshaft rotates.  about 3 times is 3.07, 3 and a half times is 3.55, etc.  make a mark on the driveshaft to make it easier.  if the rear axle is a posi, then you'll need to jack up both rear tires and rotate the tires around once.
Thanks. I may go ahead and pick it up. At only $100 for a drum-to-drum 8.25, it seems too cheap to pass up. It looks like I will one day be replacing the whole drive train since an AX-15 swap will require a TC and bell housing.
Can I reuse my existing driveshaft? I currently have no lift (probably negative lift with my tired springs and blown shocks) but one day I will probably do a 3" lift.
