PEEJ Posted November 21, 2014 Share Posted November 21, 2014 What does it take to make 94 XJ buckets mount on Comanche bucket seat brackets? Thanks Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 21, 2014 Share Posted November 21, 2014 Fab skills. 1994 was the seat change year. 1993 and below seats will bolt directly to the MJ brackets, 1994 and will not. But you probably already knew that. Maybe someone has done it and will chime in. Link to comment Share on other sites More sharing options...
FrankTheDog Posted November 21, 2014 Share Posted November 21, 2014 95 was the change over year to the new style brackets with the floor and side reinforcements. Same year they put the drivers side airbag in. I have 92 and 94 XJ's, the seats and brackets are identical. I think I've had every year of the XJ except 84,85 and 01. Link to comment Share on other sites More sharing options...
johnj92131 Posted November 21, 2014 Share Posted November 21, 2014 What does it take to make 94 XJ buckets mount on Comanche bucket seat brackets? Thanks Unbolt XJ mounts from seat. Bolt on MJ mounts to seat. 94 and prior. 95 and later are different and a bit more complex to adapt. I am doing that now. Why are you changing seats? Link to comment Share on other sites More sharing options...
HOrnbrod Posted November 21, 2014 Share Posted November 21, 2014 Yep, my mistake. I was off by a year. Link to comment Share on other sites More sharing options...
joester1908 Posted November 21, 2014 Share Posted November 21, 2014 Should be able just to switch the brackets. Unfortunately, I swapped out my bench for buckets, and my brackets were rusted through and not structural at all. I should have kept them, but I didn't. Hindsight is 20/20... Link to comment Share on other sites More sharing options...
PEEJ Posted November 22, 2014 Author Share Posted November 22, 2014 I am going from MJ bench to XJ buckets.Got a sweet deal on a nice set set of 94 XJ buckets in perfect shape and found a set of MJ brackets on C.C. Link to comment Share on other sites More sharing options...
Motorcharge Posted November 22, 2014 Share Posted November 22, 2014 Fwiw if you can adapt 95+ brackets to work ZJ and WJ seats will bolt directly to the base. They're a direct bolt in swap in 95+ XJs. Link to comment Share on other sites More sharing options...
