Through side bed exhaust
Building my exhaust. I decided I wanted to run the pipes and muffler high in the frame, and have nothing exit under. So I cut a hole in the side of the bed, and ran exhaust there.
The muffler will mount high under the bed, just in front of axle. Its a same side IN / OUT. Its a larger muffler, for a deeper sound.
I'll be putting an 8" flex pipe near header to prevent header cracks.
I'll be wrapping the headers (already done). And wrapping most of the exhaust piping. For a few reasons, one the pipe runs near the transmission and I want to keep heat down.  And the hotter the exhaust gasses the better the flow. An Exhaust that runs too large of a pipe, or too long of a pipe will have issues, as the gasses cool. (Its dry where I live, so I'm not worried about rust due to moisture in the wrap)
I'm going extreme on the mounting too, to insure proper weight, and strength. multi rubber isolators.
(Exhaust is not not done, that tip is just hanging in these pictures)
Image Not Found
Image Not Found
  • 4 weeks later...
  • 3 weeks later...
Finally done, took awhile. other things came up and what not... anyway,.  It came out just like I envisioned. I wanted to tuck the muffler higher, but it should be fine where its at.
custom 2.5" down pipe with 2 O2 Sensor ports (factory and wide-band).
2.5" flex pipe to prevent stress on header.
2.5" band clamp to allow easy removal
heat shield on exhaust pipe near transmission
long straight mid pipe 5ft long. ( I'll add a Cat there)
muffler mounted under bed, in front of rear axle. same side IN / OUT. 3 hangers for support. Band clamp to allow removal of muffler.
Pipe bent up and around the frame for exit.
burnt blue exhaust tips.
Tip, mounted angled down a bit
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
That's cool I like it, is that a FM 50? Post a sound clip pls.
  • 1 month later...
Well finally started the engine!
Here is it idling, and ~2000RPM
Kinda sounds hollow, or tinny.  I was hopping for a deeper sound. Maybe I'm used to V8's. I think I'll put a high-flow cat, hopefully that will take out the tinny sound.
So, let me know how you all think it sounds.
